I have two animated layers that are supposed to move simultaneously in sync with each other. One is an image layer, the other a vector.
The objects are set to stop and start at the same places on the timeline. But the image layer object overtakes the vector object (speed-wise) and arrives at the second point before the vector layer object, which then catches up at the second point.
Is there any way to join the objects/layers so that one is dragged along with the other?
I can share the file if someone tells me how.
Thanks again.
