parenting to a bone chain
velvetelvis70
Post by velvetelvis70 »
Hi - Hoping someone might know this? I have strands of hair on separate layers but quite close together and have drawn chains of bones along them to animate -
If I select the layer and parent it to the top bone in the chain it just responds to that one bone.
If I just adjust the influence area of each bone in the chain then it overlaps the other strands (blades of grass would be a similar problem)
Is it possible to parent a layer to a chain of 20-odd bones?
Re: parenting to a bone chain
Of course. Use "Flexible binding" (the default) instead of "Layer binding". Since you did the latter one, you must release those layers first - it's in the menu. Read the manual about "bone offset".
jezjones29
Post by jezjones29 »
I agree with slowtiger, the trick is with the bone offset tool. You may also be able to get away with using just one or two layers this way.
have you considered point binding? (or even point animation?) (and that would also allow the layers to be greatly simplified) also take a look at viewtopic.php?f=13&t=23650&p=130578
