Delete a Keyframe
Locked
rhenson
Delete a Keyframe
Post by rhenson »
Hi, if I want to delete a keyframe I didn´t found another way than to klick the delete button in the timeline. In former versions it was possible by pressing delete on my keyboard and (I think at least) by rightklicking with the mouse. Is it a bug ?
Lost Marble
Post by Lost Marble »
If you press Alt+Backspace, you can delete keyframes.
We had to change this because in Moho 5 you can draw shapes at any frame. This also means that you can delete points/shapes at any frame. This would have caused a conflict if the delete key worked on both points/shapes and keyframes. So, to delete keyframes you now need to press the button in the timeline, or hit Alt+Backspace.
Locked
