I recently updated to moho 5.2.1 and have encountered a lot of crashes, whenever I try to move the camera.
I have had to turn off all my png layers to even get the camera to move very slightly, but this only works occassionaly, The rest of the time it just crashes.
The .moho file size is about 50mb.
I have made other files about this size in moho 5.2 and did not have a problem.
Also, I saved it then reopened it and the camera movement values for x and z, for some reason swapped.
I had another issue while attempting to render-
I press control R and all the graphics are there, but when I export the animation, it has broken graphics all over the place. If I use this same file in a batch render situation it works fine. Very strange.....
Can you please let me know if this has happened to anyone else and any possible fixes.
Thanks
suspected bugs with 5.2.1
- Lost Marble
Can you zip up the Moho file and all the images it uses and email it to support@lostmarble.com? The camera thing you describe is not a known bug, so seeing the actual file could be very helpful.
