Exporting with transparency issues Windows 7 ?
daney7g
Post by daney7g »
Hi all i need some help if you can, im a new user of anime studio pro my version is 9.2. I've been following through the tutorial book with no problems until tutorial 6.7, this is the one that provides a smoke and fire particle animation to render out in order to demonstrate savings on render time by using pre rendered video. I have not been able to get it to match the quality of the video provided in the tutorial folder i have spent a good few hours trying out different combinations to no avail.
Has anyone else experienced an problem with exporting the alpha channel in windows 7 using the Quicklime codecs. Any insight would be appreciated.
Thanks Dane
"If you do nothing, nothing happens!" Jacque Fresco
jessica951
Re: Exporting with transparency issues Windows 7 ?
Post by jessica951 »
it says "This tutorial requires that you export an
animation in MOV format, which includes alpha
channel information. If you are using a 64-bit version of
Windows, you will need to complete this tutorial using
the 32-bit version of Anime Studio Pro in order to export
to MOV format."
J. Baker
Post by J. Baker »
If you're on Windows, get the Lagarith codec. http://lags.leetcode.net/codec.html
daney7g
Post by daney7g »
Thanks for your answers, Jessica 951 i did use the 32 bit version because i was using the quicktime codecs as stated in the tutorial, which only work in the 32bit app. J. Baker thanks for pointing me the way of that codec ill take a proper look at it soon. The export issue was specific to the particle effect, i have tried the exporting general transparency using standard masking and it works fine.
<3
jessica951
No problem! Check out my blog :D
daney7g
Post by daney7g »
I had a look at your blog Jessica it's awesome. I love your characters there coming along nicely looks like your improving on them. Bo is cool, super cute :D and farnham is looking slick indeed!
<3
jessica951
daney7g wrote:I had a look at your blog Jessica it's awesome. I love your characters there coming along nicely looks like your improving on them. Bo is cool, super cute :D and farnham is looking slick indeed!
<3
Thanks a bunch (: I'm working as much as I can to start on the animation haha. Stay tuned!
