Moving keyframes
JCook
Moving keyframes
Post by JCook »
I've made an animation, and now my client wants to put some new animation into it. What I need to do is to take all the keyframes starting at one position and move them further along in time so as to make room for the new part. This entails moving all the keyframes for a whole bunch of layers all at once, so that they stay in the same relation to each other as they are moved, and after they're moved, that part of the animation would stay the same as it was before the move, just starting at a different time. Since Moho will only let you see one layer's keys at a time, this is extremely difficult to do. Is there any easy way to do this, or a workaround of some sort?
thanks, Jack
ulrik
Post by ulrik »
There is a "Rescale keyframes" under "Animation"
meny which let you move the entire document so many keyframes that you want, let's say your animation starts at key frame 1 and ends at 200, you want it to start at 150 and then it will end at 349
[/img]
JCook
Post by JCook »
Thanks, ulrik, I think that will do the trick. I knew about Rescale Keyframes, but I didn't really know it could simply move keyframes. I think it'll work.
Jack
