Optimization of text layers for SWF export
sarapis
Post by sarapis »
I'm a new anime studio pro user and having problems exporting to flash in terms of file size. When all I have is one background jpeg and one alpha'd PNG, I get the size down to about 20k as a .swf export. I then add a single layer of text that scales and translates (no shear, nothing like that, just scales and moves, and not even at the same time) and the file size jumps to 100k. We're talking nine words of text, nothing special about them. No gradient fills, nothing.
It seems like it's not treating them as vector and I can't figure out why. Any thoughts?
Thanks so much for help!
Yosemite Sam
Re: Optimization of text layers for SWF export
Post by Yosemite Sam »
What version are you using?
Jimmy Mills
Some of my Moho Pro work.
My Demo Reel: https://youtu.be/_kSCno4Wd3c?si=gNT7d27R7sM4jjqq
Buddies Ep 4: https://youtu.be/f8Zbzo2mpHA?si=4EyxhBOrgOxkDoSO
Text has a lot of points in the outlines. I'd do that part in Flash, if I really need to produce an SWF.
sarapis
Post by sarapis »
Yosemite Sam wrote:What version are you using?
Using Pro 9.
sarapis
Post by sarapis »
slowtiger wrote:Text has a lot of points in the outlines. I'd do that part in Flash, if I really need to produce an SWF.
Apologies for the noob question, but how would I go about doing that? Product the text part in Flash and export to an .avi or something and then import that as a layer in Anime Studio?
sbtamu
Post by sbtamu »
You could just make the text in AS like you are doing then save one frame of the text as .png with all other layers off then import that png back into AS and then turn the vector text off.
Sorry for bad animation
The important question should be: which format is your final output format?
sarapis
Post by sarapis »
slowtiger wrote:The important question should be: which format is your final output format?
SWF is my final output format. Making a banner ad.
In that case you need to work in Flash anyway, to incorporate the code for linking etc.
