Help using/creating Sketchy Effect??
cartoonkreator
Post by cartoonkreator »
Hello scripting masters, I am working on a project using AS pro 6 that has a very simple hand drawn feel to it, and I have used the "Apply Sketchy Effect" to give it that squigley feel. However as you can see from this example :
http://youtu.be/HyzY2kmShe8
it gets a bit out of control in the close ups towards the end. I have no experience writing or working with scripts in AS, So I am wondering how I can get the same effect but have some control over the amount of shakeyness.
Thanks
chucky
Re: Help using/creating Sketchy Effect??
Post by chucky »
Use the vector noise settings in the layer palette instead of the script, there are more options perhaps.
More again if you update to 9 like frame interval to keep it to 2's or 3's or whatever I think there's a whole new way that it is implemented.
You could try different settings in the close ups to reduce the wiggle.
