render problems
Maxwell
render problems
Post by Maxwell »
Hello again
so this time i noticed something weird going on when i render my character
http://www.youtube.com/watch?v=qq2cmpCO ... e=youtu.be
as you can see it renders out the mouth in a weird way
here a better view
http://www.youtube.com/watch?v=S3GWdJyH ... e=youtu.be
now i know for a fact that the mouth has hidden strokes
but when it renders it just shows them anyway and it looks really weird like she has a little mustache going one
i rendered at the finest resolution
is it because of the masking? i don't think so but here is an example how i got my layers masked
this is the main bone layer:
these are the lips
the black part of the mouth:
the teeth and the tongue are just masked nothing special
any help would be appreciated
thank you
neeters_guy
Re: render problems
Post by neeters_guy »
This thread might be useful: masking line bug fix at AS9
Is it necessary to use masking for this? The mouth construction could done in one layer, something like this:
funksmaname has a short video using shape stacking: quickstacks
If you have the time, I recommend all his videos where he covers shape stacking in great detail:
Shape stack order explained (UPDATED with pt 3)
Hope that helps.
Maxwell
Re: render problems
Post by Maxwell »
thank you this will be useful
i have done some research of my own and i found a really simple solution... i just hit the lines underneath the inside of the mouth... might not be the professional way to do it but it worked for me
i will look up this content so that i may learn more for the future thank you :D
Maxwell
Re: render problems
Post by Maxwell »
so i expanded the mask by a pixel and i still have the same problem
i would love to solve this problem because i want to use masking for this...
Maxwell
Re: render problems
Post by Maxwell »
neeters_guy wrote:This thread might be useful: masking line bug fix at AS9
Hope that helps.
is ti possible that when you render from a distance the line will appear but when you render up close the line is gone? i did everything as it said in the post... it's really weird...
