Weird SWF export from Anime Studio Pro 9.0
TonyPolizzi
Post by TonyPolizzi »
Hi all,
I have a problem I am unable to solve by myself.
Every time I use characters from the Character Wizard, when I export to SWF, the seams of the different parts of the character are visible and the layers seems to be not in the correct Z-order. Any hints about that? Thank you.
Re: Weird SWF export from Anime Studio Pro 9.0
A guess: the characte uses patches. Patches are not supported in Flash.
TonyPolizzi
Thank you very much for you information, slowtiger.
I will try to avoid the use of patches whenever I need to export to SWF.
Check page 286 of the Users Manual for a detailed list about what can and can't be exported to Flash.
TonyPolizzi
Thank you selgin, already done.
Now I know that I must plan my character creation more carefully.
if you have ASP9, patches are no longer necessary - why don't you use smart bone actions?
TonyPolizzi
funksmaname wrote:if you have ASP9, patches are no longer necessary - why don't you use smart bone actions?
Yes, you're all right. That's the main reason why I upgraded to ASP9.
But every time I need to use the characters from the Character Wizard, I have to modify the character itself by deleting the patches and modifying the segments, isn't it?
aaron
Post by aaron »
Anime Studio exports films to .swf, but without certain effects which are not part of the .swf file format. Just check the manual provided with the flash
