Random Switches in Switchlayer (new script)
rylleman
Post by rylleman »
Here's a new script I wrote because I thought it was tedious to add random switches by hand...
Random Switches script. --Right click to download.
Installation: Just put it in your scripts/menu/other folder.
Usage: Select a Switch layer and run the script. The parameters you can set is the range to add keyframes in, the interval between keyframes and whether the first keyframe always should be keyed.
I hope it will be of some use to you.
Rai López
Post by Rai López »
Uf... :D THANK YOU!!! (again ;))
EDIT: :shock: WOW!!! VERY USSSEFULL! :D I like it so much!!! Definitely: :arrow: ...THANKS!
mr. blaaa
Re: Random Switches in Switchlayer (new script)
Post by mr. blaaa »
rylleman wrote:Here's a new script I wrote because I thought it was tedious to add random switches by hand...
Thx for this script, thx for any good script from moho users with lua knowledge.
Now its up to us to see what we can create with it :wink:
