Sometimes I need to zoom out (timeline) to select a bunch of keyframe dots, then I will need to move them left or right, etc. the problem for me is, it takes me 5 or 6 tries to finally "hit the target", that is, to be able to click within the single pixel (apparent active area for making a selection) within a single dot, so that I can move the entire group of keyframe dots.
If it weren't for this one item, I could probably work 5 times faster when assembling an animation. Also, one would assume that the right and left arrows would move keyframe dots once they are selected, but I guess not. And come to think of it. I need to find a hot-key list somewhere, as so far my discovery of shortcuts and hot key has been on the slow boat. I purchased via the 30 day trial/download which came with zero documentation, so perhaps this is where I went wrong.
I've also noticed on several occasions when working really intensively, I've had to save then quit the app, and restart just to get some of the feature to work properly again, e.g. to add a new layer via the layer's menu, which absolutely will not work sometimes after I've been working on a project for a few hours.
That said, great program by the way, the above are mostly just quibbles. I can see with just a bit more bug zapping, and perhaps a few more controls (such as audio panning and generally being able to overlap audio tracks with different level settings and so on), I can see where ASP may at some point be a genuine heavy hitter. And yes, I also realize that it may just be me, that I've missed controls and features which may already be there.
I'm still and always a student of animation.
Thanks much.
Timeline "dots" too small.... or??? + general feedback.
Re: Timeline "dots" too small.... or??? + general feedback.
Even the trial comes with the full manual under the Help Menu surely?
- ErikAtMapache
I put a feature request in with SmithMicro to increase the size of the control boxes in the layer control (that square with the 8 boxes that you resize with) -- I usually rotate instead of resizing when I miss.
Find me on Content Paradise at:
http://www.contentparadise.com/SearchRa ... xt=mapache
Yes, I have been finding more help at the SmithMicro site lately.
Control boxes? Every time I work with this software lately, I feel like it is an eye-hand coordination contest trying to hit those timeline dots, just to slide elements back and forth. So far my batting average is around 120.
I did however find a PDF of all of the hot-keys, but there were none to move selected timeline dots back and forth. Seems like everything from Photoshop, to you-name-it allows this kind of fine tuning from the keyboard once the element is selected. So to have to always zoom and and out of the time line just to move a groupof selected dots back and forth is a real time-waster in my view.
Just to be clear, these are relatively small objections compared with the sheer utility of this software. It seems like it only needs a couple of improvements here and there launch this one into the "super good" category.
