Can't find the tutorial: How to make text follow path
Regular follow path is easy, I'm trying to have text follow a path so each letter follows the path, not like an entire word or sentence.
Can't find the video tutorial that I watched once before which showed the trick to get text to follow a path, one letter at a time.
Or if someone knows the step - it was easy if i remember right, please refresh my old brain...
- hayasidist
Re: Can't find the tutorial: How to make text follow path
select the layer you want to follow the path, then when you choose the follow path tool hold ALT when you click the path to follow.
Doh! That's too easy
Thanks
Thanks
- hammerjammer
When I hold the alt key and select the path to follow, nothing happens. it doesn't work.hayasidist wrote:select the layer you want to follow the path, then when you choose the follow path tool hold ALT when you click the path to follow.
Hammerjammer
- Víctor Paredes
Be sure to create a vector layer instead of a text layer (uncheck "create text layer" in the text window). Right now, text layers can't be bent, but you can bend a vector layer.hammerjammer wrote:When I hold the alt key and select the path to follow, nothing happens. it doesn't work.hayasidist wrote:select the layer you want to follow the path, then when you choose the follow path tool hold ALT when you click the path to follow.
- hammerjammer
Thank you. That was making me crazy. I found that when you create a text layer in the "Layer toolbar" on the right of the screen, your not given the choice to uncheck "create text layer". that little box is not there. BUT, if you click the "T" in the Tools toolbar on left, then you are given the choice to check or to uncheck "create text layer". This was and is very confusing to me. I thought they would the same thing, but they are slightly different than each other.selgin wrote:Be sure to create a vector layer instead of a text layer (uncheck "create text layer" in the text window). Right now, text layers can't be bent, but you can bend a vector layer.hammerjammer wrote:When I hold the alt key and select the path to follow, nothing happens. it doesn't work.hayasidist wrote:select the layer you want to follow the path, then when you choose the follow path tool hold ALT when you click the path to follow.
Thanks for your help Selgin
Hammerjammer
Hammerjammer
- hayasidist
yeah -- I think the OP dates back to the AS8 days when there wasn't a "text" layer type - just vectors... a lot of info in "older" posts has been overtaken by developments in AS... wondering if it might be time (or maybe starting with the arrival of AS10) to have version specific "how do I" etc...???
- uncle808us
What if you want one letter to show up then the next and so on.. Like on a ticker tape.
http://uncle808s.blogspot.com
- uncle808us
Got the whole thing following but have some nasty black lines. Any ideas?
View My Video
View My Video
