Select lose ends
chucky
Select lose ends
Post by chucky »
Is there a script that selects the points at the end of a line or the inverse of that?
This would be useful when you want to change the line thickness but not the endpoints if they are tapered.
Re: Select lose ends
Not the same script, but similar use:
Linewidth checkbox: don't modify points with value zero
