Action doesnt react on the smart bone movement?
Admiral Halsey
Guys! I have a huge problem! Today I spent half of the day on creating smart bone action for head turn, it took me like 5 hours of insane point tweaking and now when I done it I found out that it doesnt work! Head is not turning and not following the smart bone. What might be the problem?
- funksmaname
Re: Action doesnt react on the smart bone movement?
layer binding maybe? select the layers and 'release binding' - might fix it...
Another top tip: don't spend 5 hours on something with out regular testing
- Víctor Paredes
- Are you sure the bone and the action have exactly the same name?
- Did you rotate the bone in the action?
- Is the vector layer directly inside the bone?
That's are the possibilities I can think now.
Admiral Halsey
No, I have a large group layer for head wich consists of 2 bone layers (eyes and mouth) and group layer for hair. I need those sublayers because I have different masking options for hair, eyes and mouth. Can this affect on smart bone actions?Is the vector layer directly inside the bone?
- Víctor Paredes
Smart bone actions only works for vectors directly inside the bone layer. If you have more bone layers, you will have to create smart bones on each one and animate them independently. Be sure the names of the bones be different on each bone layer.Admiral Halsey wrote:No, I have a large group layer for head wich consists of 2 bone layers (eyes and mouth) and group layer for hair. I need those sublayers because I have different masking options for hair, eyes and mouth. Can this affect on smart bone actions?Is the vector layer directly inside the bone?
Admiral Halsey
selgin wrote:Smart bone actions only works for vectors directly inside the bone layer. If you have more bone layers, you will have to create smart bones on each one and animate them independently. Be sure the names of the bones be different on each bone layer.Admiral Halsey wrote:No, I have a large group layer for head wich consists of 2 bone layers (eyes and mouth) and group layer for hair. I need those sublayers because I have different masking options for hair, eyes and mouth. Can this affect on smart bone actions?Is the vector layer directly inside the bone?
Oh, God! But is it possible to copy layer actions from one smart bone to another? And can I create a main smart bone for head movement which will control those sub-smart bones?
- funksmaname
you could probably use a script to have bones on the master layer effect those on the sub layers ('bone parent master' here http://www.mikegreen.name/)
You can copy actions as normal by putting an instance of one action into another - though you probably need to do that, you can just rename the action to match a different bone!
Admiral Halsey
Thank you, guys. I see bunch of additional routine work coming my way.
Btw, I saved the script but I don't really know how to install it? Do I need to copy it somewhere?
- funksmaname
it's an embedded script... the instructions are there. Copy your bones to the parent layer and add the embedded script to the parent (in layer settings pallette, bottom left).
After that, moving that bone should move the sub layer bone too.
Admiral Halsey
I copied child bones to parent layer, added a script, moved a parent bone and... nothing happened. Im such a loser.
