Audio Out of Sync when Exported
Mr_Putershmit
Post by Mr_Putershmit »
Apologies if this has been answered before.
When I'm working in AS everything is fine. After I've exported the animation the Audio and Video are completely out of sync and seem to get worse (further apart) as the video progresses.
I've tried exporting in every different format that I can to no avail.
The audio file is a 16Bit 44.1 wave file
I'm using AS debut 9 on a Mac Pro Quad Core 2.66 6G Ram OSX 10.6.8
Mr_Putershmit
Re: Audio Out of Sync when Exported
Anyone? This is killing me
sbtamu
Post by sbtamu »
We need more information. What format are you rendering to? If you are rendering to AVI, this is a common issue. It will sync up after you do your final render.
Sorry for bad animation
He'll be exporting to .mov, on a Mac.
Personally I never had sync problems with AS. My rule is to always test stuff in render, it doesn't count if something is in sync in AS playback since this can be slower than my actual frame rate.
Just a guess: have a look into your Audio MIDI Setup (it's in "additional software" in "Programmes") and check wether all outputs and inputs are set to 44,1 KHz. I remember having trouble with this bit because some other software was able to change this setting, causing other toplay back at wrong speed.
