Masking in AS9?
Admiral Halsey
Masking in AS9?
What's happenned to masking in version 9? Ive noticed that some of my old masks doesn't work as it should even if I didn't change anything.
Admiral Halsey
Re: Masking in AS9?
Oh, nevermind. I figured that out already.
Re: Masking in AS9?
Hi! I'm having the same problem. Masking doesn't seem to work right in AS 9. What did you figure out?
Re: Masking in AS9?
As usual, I figured it out too, right after I posted. Thanks!
- ErikAtMapache
Re: Masking in AS9?
Wait, what was the problem?
As a humble and general suggestion -- if you had a problem but it was some minor thing, there are probably ten other people who had the same issue but were not bold enough to say anything (and the developers may not even know there is an issue). I would suggest that when anyone has an issue they bring up and then figure it out, that they just add a quick sentence saying what they did -- for example: it didn't render but I forgot to change my preferences. This helps other users solve similar problems and the developers fix usability bugs.
I hope I didn't overstep my bounds...
Find me on Content Paradise at:
http://www.contentparadise.com/SearchRa ... xt=mapache
- funksmaname
Re: Masking in AS9?
I think you're right Erik - to collect responses saying "I have the same problem" | "never mind I fixed it" doesn't really help in the long run, and if you ever make the same mistake you won't be able to remind yourself of that simple fix (speaking from experience)
Re: Masking in AS9?
Sorry about that, you're right, I should have explained.
For some reason, the masking instructions for each layer were changed when I opened the file in AS9.
I accidentally noticed this when I unchecked one of the layers.
I did however, open another file in AS9 that I built in AS6, and the masking was right.
I'll be more specific in the future.
Thanks
Thanks
