Q: ctrl, shift and alt on a button tool?
Breinmeester
Post by Breinmeester »
Hello,
I'm writing a script which i want executed at the press of a button, so i included it in the _tool_list with the 'button' mark.
Here's my question: I want the script to act differently if alt, shift or ctrl are held. How can i accomplish that?
So for example, i have the script included in the _tool_list like this:
button lm_scriptname k
Now i want it to do different things when you press [ctrl] + [k], [alt] + [k] and [shift] + [k].
Ive tried:
function lm_scriptname:OnKeyDown(moho, keyEvent)
	if (keyEvent.altKey) then
		print('Alt down')
		return
	end
end
but it doesn't work.
More importantly, if i press [k] the script runs, but if i press [ctrl] + [k], [alt] + [k] or [shift] + [k] it doesn't.
Any advice anyone? Thanks!
PhilIcare
Re: Q: ctrl, shift and alt on a button tool?
Post by PhilIcare »
Hi
The shortcut for your tool is "k". So it runs when "k" is pressed. "[Alt]+k" is another shortcut, not equal to "k", I guess.
The issue would be :
button lm_scriptname    ALT+k    // how to specify it?
button lm_scriptname    K
button lm_scriptname    CTRL+k  // idem
I don't know if it's possible.
Another issue would be :
- One key for the tool (let's say "k")
- One another to operate (let's say "d" like "do", though it could be the same, ie "k")
tool  lm_scriptname    k
function LM_ScripName:OnKeyDown(moho, ev)
  if ( ev.key ~= "d" and ev.key ~= "k") then
    return
  end
  if ( ev.keyCtrl ) then
    -- do your stuff
  elseif ( ev.keyAlt ) then
    -- do your stuff
  -- and so on
  end
end
Hope it helps...
Phil
PS : apologies for my ugly english
