The standard project size of Anime Studio Pro is 872*596 on 24 fps, does anyone know if there is a way to adjust it?
I would like it to be 1920*1080 on 25 fps.
I tried adjusting the startup file, but that doesn't work when you open a new project, only when you start the application.
The "New from template" feature works, but I'd rather never see 872*596 on 24 fps again.
Is there a file somewhere I could edit to get the new-project settings right?
Startup file / New file issue
- Víctor Paredes
Re: Startup file / New file issue
In project settings there's a "Save as default" button.
Somehow I've never seen that button!
Thanks a lot!
Thanks a lot!
