how to fix jitter problem
ahzra
Post by ahzra »
hi all, few weeks ago i put a video about full body turn test.
http://www.youtube.com/watch?v=fT6UVv6G ... ature=plcp
and some one told me that i had jitter problem at shoulders . i tried to find a solution for it but i could not know the way. if some one here could help me and tell me the solution to fix this problem . that would be nice
regards :D :D
chucky
Re: how to fix jitter problem
Post by chucky »
Sorry ahzra but I can tell from the video alone. Good luck fixing it though :D :)
The video has too little information but I am going to take a wild guess and say that you are using depth sorting in a group layer to do the layer ordering?
If so, sometimes layers will "flicker" like that when there is depth sorting by true distance and the layer gets close to order change and sort flickers. Just guessing. Can't help without the file or seeing how it's constructed.
ahzra
Post by ahzra »
heyvern wrote:The video has too little information but I am going to take a wild guess and say that you are using depth sorting in a group layer to do the layer ordering?
thanks heyvern , you are right i used depth sort of layers . but i dont know how to fix the flicker problem or enhance it , this is the anime studio file . if you could modify it to fix the problem
http://www.mediafire.com/?obyjmilh597m79b
regards :D
ahzra
Post by ahzra »
chucky wrote:Sorry ahzra but I can tell from the video alone. Good luck fixing it though :D :)
thanks chucky , here is the anime studio file if you could fix it :D
regards
Ha! Simple fix, but I will let you handle it.
The jittering is caused by the layer order key frames!!!
In your file you have layer order keys on frame 1 and 2. Frame 1 the arm with the flicker (your right, character's left arm) is on top, frame 2 that arm is behind. On the LAST frame the layer order key has the arm BEHIND. When it loops to the start you get 3 keys next to each other "flickering" the layer order of the arm back and forth. If you want this to loop smoothly make sure your key frames match up on the last and first key frames. I would suggest just eliminating the frame 1 key as it isn't needed or if it is needed just put the right arm behind the torso to match the other keys.
ahzra
Post by ahzra »
heyvern wrote:Ha! Simple fix, but I will let you handle it.
thanks heyvern i will try your solution . and special thanks for being interested :D
