Hi.
I have just bought AS Debut 7. (version 7.0)
I'm following the tutorials, and the current one requires me to copy the render window and paste it into my paint program to make a texture file. However there is no way to do this on my render window. In the tutorial it shows a menu that does not exist (I think) in my render window.
Can anyone explain this??
Thanks,
Mick Berg.
Can't copy from render screen
- funksmaname
Re: Can't copy from render screen
I think this is a limitation of debut - you probably have to export a single frame PNG instead from the file menu...
You still should be able to make an ordinary screenshot.
OK, I'll have to learn how to do that.funksmaname wrote:I think this is a limitation of debut - you probably have to export a single frame PNG instead from the file menu...
Yes, I already did it with ScreenHunter.slowtiger wrote:You still should be able to make an ordinary screenshot.
Thanks all,
Mick Berg.
- InfoCentral
How To Capture a Screen Shotslowtiger wrote:You still should be able to make an ordinary screenshot.
