3D object gray texture
Asterix
Post by Asterix »
I imported a obj with Ultimate Unwrap 3D, and I get a grayed texture.
http://imagebin.org/223269
ASP 7.1
rocky53204
Re: 3D object gray texture
Post by rocky53204 »
I'm only posting this because no one has sent you an answer yet.
Imports of obj files are hinky to impossible... (see: viewtopic.php?f=9&t=22832&p=125934&hili ... es#p125934
In your case you may be trying to import an object lacking texture and/or material information. Trying to cope with the same problem...
rocky53204
I downloaded a file that has an .mtl (material) file that references graphic files on the machine they were produced on... hence my computer cannot display the missing textures. I will try to manually edit the .mtl file. (it's a text file) to re-direct file seeks to something I have. You might want to see if you have a similar situation.
Asterix
Post by Asterix »
rocky53204 wrote:I downloaded a file that has an .mtl (material) file that references graphic files on the machine they were produced on... hence my computer cannot display the missing textures. I will try to manually edit the .mtl file. (it's a text file) to re-direct file seeks to something I have. You might want to see if you have a similar situation.
Ha the Unwrap 3D exported the texture correctly, the problem is the mtl. It need to change the jpx by png and it worked.
ASP 7.1
