Trim 2 objects
Asterix
Trim 2 objects
Post by Asterix »
I want to create that red moon shape.
Cut out the portion of a object using the shape of another.
Thanks
ASP 7.1
Re: Trim 2 objects
I think masking is the simpler way in this case.
Re: Trim 2 objects
it would be quite easy to create this as a shape manually (points at the corners, curves on the rounded parts) - this is easier and quicker than masking but would be near impossible to animate nicely though - if the inner 'cut' circle needs to grow/shrink or move, masking is most definately the best option.
