Python Scripting for AS
- InfoCentral
I just noticed that Papagayo is written in Python and it integrates nicely with AS. So is it possible to write scripts in Python for AS?
Re: Python Scripting for AS
Uhm, AS only reads a text file created by Papagayo. That's all. No Python works within AS, it's all LUA.
SlowTiger is right about Papagayo, but you could try this:
http://labix.org/lunatic-python/
Not sure how useful it would be though as probably all of the useful things you can do in Python are probably not supported by the AS scripting interface anyway.
- hayasidist
bearing in mind that the .anme files are just text files then python could be used to do "script"-like things outside AS - e.g. delete all keyframes between frames a and b; insert keyframes to give a parabolic trajectory to layer x between frames a and b; unload all keyframes in switch layer z to a .dat; create a .anme from this .svg ... of course you'll need to figure out the .anme file format (which has a nasty habit of changing between releases)
