how to disable visibility of an object in timeline?
lda.com
Post by lda.com »
If I add one object starting from anywhere after zero, its showing me a visible icon in timeline and by adding key frames I can make it invisible.
but same option not showing for objects starting at zero
How do I make them invisible after a particular frame?
Re: how to disable visibility of an object in timeline?
there are two ways:
- go to the frame you want, open the layer proprieties, uncheck "visible"
- go to the frame you want, now, in the layer window, click the triangle at the right side of the layer name and uncheck "visible"
lda.com
Post by lda.com »
Thanks
