Library button.
sbtamu
Library button.
Post by sbtamu »
With Pony's new tools, I am running into an issue with having to hit the library button each time I select the script box.
Any ideas what I can do? AS7.2 pro.
Thanks
Sorry for bad animation
jonbo
Re: Library button.
Post by jonbo »
I run WIN 7 on my PC, and there's an option to change the display from 100% to 125% to 150% to make the text easier to read. When I change it to higher than 100%, I lose some space like what you're running into. Maybe look at changing you display settings if you can, there's another checkbox after the one getting cut off in your screen shot.
Re: Library button.
search the strings.EN.txt file and modify this line
/Windows/MainLayer/Library=Library
To this
You can make the same with the Character Wizard. In my case I have this:
/Windows/MainLayer/CharacterWizard=CW
ponysmasher
Re: Library button.
Post by ponysmasher »
You can also change the texts of scripts. Just open it in a text editor and search for the string you want to change, for example "Change all keys relatively".
It's hard coming up with texts that are both short and descriptive...
sbtamu
Re: Library button.
Post by sbtamu »
Thanks for the tips. I I know what the check boxes are for now so I shortened descriptions.
Thanks.
