shadow in export to swf
narven
Post by narven »
hi there
im really newbie in moho...
i've been doing some test... to see the capabilites of the program and if can get the hand of it... but when i aplay som shadow into a layer, and i make a render ... everything is ok, but if i export to swf, it doesnt have any shadow :( :(
what im i doing wrong???
pintman
Post by pintman »
I think there are some restrictions on the SWF-Export. This might be one. Perhaps someone can post a list - or show link to a list - where these restrictions are named.
bakera.de - home sweet home
bulb-publications.de - films sweet films
Rai López
Post by Rai López »
There is a complete list and other explanations in the Manual: Reference Folder of the Index --> Flash Tips.
narven
Post by narven »
What Can't be Exported
  • brushes
    fill and line effects (except gradients)
    layer effects (shadows, shading, layer blur, motion blur, etc.)
    image warping or 3D movements in image layers
    image layers that use progressive JPEG images (Flash can't handle progressive JPEG images)
    layer masking
    3D layers
bahh this sucks... :| if there isn't a shadow... there is nothing buaaaaaaaaaaaaaaaa :cry:
mr. blaaa
Post by mr. blaaa »
yes this is one of the limitations...
but, does it NEED to be swf?
how about quicktime or real format?
myles
Post by myles »
Lots of 2D character animation doesn't have proper shadows, having either no shadows or at most a little circle/ellipse under the moving characters. Check out several of your favorite 2D cartoons to confirm this.
If you made a second copy of your objects (preferably after you've animated them), and coloured the copies black (or gray), you could make sharp-edged SWF shadows.
You could also render out to AVI and wrap this in an SWF using one of the movie to SWF converter programs. I believe this tends to create fairly large SWF files in some circumstances.
Another format than SWF, as mr. blaaa suggested, is probably a better solution for cartoons detailed enough to require detailed shadows and other effects.
Regards, Myles.
-- Groucho Marx
mr. blaaa
Post by mr. blaaa »
myles is absolutely right.
the copy+paste+dark fill technique is always a good alternative if u NEED those shadows in SWF.
