How do you adjust the workspace size?
Bob G
Post by Bob G »
I've been working on two clips and just realized that the workspace in each one is quite different (one is much taller than the other) and that is causing a problem in composing a movie with the combination of the two using Adope Premiere. I would like to adjust the sizes of the workspaces so they are the same but I can't figure out how to do that. The User Manual does not appear to address this.
All help is appreciated
Cheers,
Bob G.
File > Project settings: enter identical dimensions.
Bob G
Post by Bob G »
Answered my own question....
How do you change the size of your workspace?
Step 1: From the "File" menu, select "Project Settings".
Step 2: In "Dimensions" box, uncheck "Constrain Proportions" check box.
Step 3: Adjust the values for "Width" and/or "Height" as needed.
Cheers,
Bob G.
