Here's my feature request list for Papagayo.
Delete/add words without having to re-breakdown and redoing all work.
Red bar -stop at the place where it's dropped instead of dissapearing. Playback from this point instead of from start of project.
Phonemes -every other words phonemes has a different colour, easier to navigate.
Separate voice in sentenses/blocks, quicker to position in audio with long pauses in it.
Not reset word/phonemes when moving/changing lenght of sentense/word. Keep relative positioning when moving, add blank frames in start/end if prolonging, move just the last phonemes if shortening.
Markers or a comment field above the audio.
Being able to set names of switchlayers as they're named in the switch file (mpb > mouth_7).
An easy way to add your own set of mouths and set which phonemes they represents.
More than 9 mouths. There are 39 different phonemes with 3 stress levels each in the list Papagayo uses so it shouldn't be that hard to allow more than nine?
The frame number where you are with the red bar shown somewhere.
User dictionary, words automatically added to this when typed in. I know you've said this is on you're todo list, just wanted to mention it anyway.
Being able to mark a range of frames and playback just this range. Useful together with;
Loop playback.
Wish-list.
- Lost Marble
Re: Wish-list.
Good suggestions. Just one I want to comment on:
You can do this right now. Put each phrase on a separate line in the "Spoken text" box and they will appear separated in the waveform view. This makes it easier to work with pauses in the audio file. Take a look at the "lame.pgo" sample file included with the program.rylleman wrote:Separate voice in sentenses/blocks, quicker to position in audio with long pauses in it.
Re: Wish-list.
Sorry, missed that one...Lost Marble wrote:Put each phrase on a separate line in the "Spoken text" box and they will appear separated in the waveform view.
I'm more of a "try and learn" rather than a "read the manual an do as they say" and I obviosly didn't try the spacebar.
- Lost Marble
Re: Wish-list.
Don't use the spacebar - use the Enter key to separate lines of text.rylleman wrote:I obviosly didn't try the spacebar.
