Clear animation addition
rylleman
Post by rylleman »
In addition to clear animation from Layer/document it would be nice with a command to clear animation from selected bone(s).
An improvement to all of the clear-commands would be to be able to select a range of frames to clear (keep frame1-29 and clear #30-end or clear #25-39, keep everything outside this range). You probably would have to keyframe every channel in the first frame after the clearing but that would be a minor issue.
Further it would be an improvement if you could select which channels to delete or keep.
Lost Marble
Re: Clear animation addition
Post by Lost Marble »
rylleman wrote:In addition to clear animation from Layer/document it would be nice with a command to clear animation from selected bone(s).
This is actually quite easy now that you can select multiple bones. Just select the bones you want (using shift-click to select multiples). Then delete the keyframes in the selected bone channels.
rylleman
Post by rylleman »
I know, but it would be a bit less work with a menu-command for it.
And I still believe being able to select a range and channels would be a great improvement to clear animation from layer and document.
