Is Random Looping (Cycling ) possible?
kaboom
Post by kaboom »
I'd like to cycle a layer with random actions. For example my eyes layer I want to alternate between blinking, looking left and looking right randomly for the length of my videos. Is there functionality to randomize these actions or do I have to manually set up my looping?
Not inside AS.
In older Versions of AS it was possible to use a .dat file which controlled a switch layer. I'd use some scripting to randomize the options over time, then feed that file into AS.
Do .dat files work in recent AS versions?
jonbo
Post by jonbo »
Yes, they do.
kaboom
Post by kaboom »
slowtiger wrote:Not inside AS.
can you explain in more detail if possible? or direct me to a tutorial?
Here's what I did with it:
viewtopic.php?t=20188&highlight=dat
jonbo
Post by jonbo »
If you have AS pro, there is a script that allows a DAT. file to activate actions. This would make it easy to set-up your various actions and then use the dat. file to insert them into the timeline. It would appear to be random then.
