Making Cut Scenes
Itsa_Secret
Making Cut Scenes
Hello,
This probably was already answered many times, but I'm wondering how to make cut scenes. Specifically, when I've zoomed in onto a cat licking its paw, I want to delete the tongue and give it a speaking mouth. Problem is, when I delete the tongue, it's no longer there in the whole movie. Is there a way to tell the timeline to seperate itself into pieces, so I can delete or move things without them having an effect on the whole project?
Also, can someone give me a link to the explanation on how to make your own talking mouths while using the program's already built phonetic mouth chanes?
Thank you
Thank you
- funksmaname
Itsa_Secret
Alright. The tongue is it's own layer. So what I did was I selected it, added a keyframe on the timeline, and them the next frame moved the tongue off the board. However, the program still took the move as a gradual overall move for the tongue. Thus, making the tongue flying off the cat's face at a very slow pace. I know I'm probably misunderstanding you, but I'd be greatfull if you could figure out what I'm doing wrong.
Thank You.
Thank You.
Itsa_Secret
- funksmaname
ah yeah i forgot to mention you need to either change the off canvas key to 'step' so it doesnt slowly come back, or do the same trick again - making an off canvas key 1 frame before it comes back.
If it's in its own layer, you can click on the visibility lane to toggle visibility on and off for the layer too...
Itsa_Secret
Here, check out this demo I've done for you. It should answer your question.
http://youtu.be/Rk6DPs0-PHM
