In case this hasn't been posted already...
For those unfamiliar with 3D camera tools, you can adjust the amount of perspective by fiddling with combinations of the "truck in" and "zoom" camera functions. Trucking in basically means moving the camera physically towards or away from your subject, while zooming enlarges or shrinks your subject.
Moho's default zoom level gives you a distorted perspective (objects further away look really, really far away). Adjusting the distance of the camera and the zoom level (lower) at the same time can give you a more realistic look.
Of course, for those who don't know, you can also get that cheesy effect where you zoom in on a subject while at the same time trucking out, which makes the subject appear to shrink as the background gets bigger (used in most horror films to indicate something nightmarish happening)
Camera perspective
Just like in Lord of the Rings when the Ring Wraith appeared in the forest.Of course, for those who don't know, you can also get that cheesy effect where you zoom in on a subject while at the same time trucking out, which makes the subject appear to shrink as the background gets bigger (used in most horror films to indicate something nightmarish happening)
Thanks, I'll have to play with it some but I'm sure that trick will come in handy.
Max Power
VideoDesigner77
