Can't fill shape
Asterix
Can't fill shape
Post by Asterix »
I have a couple of dots together, but it's not a shape or what. It wont fill with color. :shock:
Re: Can't fill shape
Asterix wrote:I have a couple of dots together, but it's not a shape or what. It wont fill with color. :shock:
Huh?
Have you followed the tutorial?
Asterix
Post by Asterix »
What tutorial? My best guess is Create shape tool p.146. But it won't get dotted red-white.
Asterix
Post by Asterix »
That is my main problem with this application. It's a bug or what. I zoom and there IS a closed shape. Why the Fill dose not work out. :twisted:
The best I do, it create the edge bigger. I want to fill it.
Along the top line is a "Help" button. Underneath that is a "Help..." menu item. In there are some tutorials. Work your way through them -- they're the best way on getting a handle on the software.
Share the file with us won't hurt and probably could help you better.
Asterix
Post by Asterix »
Thanks that a good idea, that is the mac version. If anyone want it in pc I will do it.
http://www.mediafire.com/?7tlz622vrce7a01
ruscular3d
Post by ruscular3d »
I make sure that none of the object interfering with the shape you wish to fill. If you have an object within the object, I move that out of the way and move it back after fill. I don't know if that is kosher but that was my discovery on this issue.
GCharb
Post by GCharb »
The two points at the bottom right are on top of each other!
Just move them apart slightly and it should work!
jonbo
Post by jonbo »
Gilles is right, that's the problem I found too. I've found using the freehand tool can give you strange results like this, better to use the add points tool instead.
Asterix
Post by Asterix »
Thanks guy's I do use freehand tool, how am I supposed to draw?
I think it's a bug, how to submit that bug?
Merci mon cher GCharb
GCharb
Post by GCharb »
Just use the add point tool (A), then click and drag, it will create a line between two points, then You click and drag from the second point, and so on...
I never use the freehand tool, even with my tablet!
Not everything which doesn't seem to work is a bug. Two points or two lines on top of each other are a common problem in all vector programs. They happen all the time, it can't be avoided, all you can do is to be aware of this if an operation like fill doesn't work.
With the freehand tool you could turn on "close shape automatically" when you need that.
RichardU
Post by RichardU »
I have a similar problem which is I can create a shape, but it will not fill. It is one of two shapes with a common boundary. I can make those without problem with simple geometrics, but the drawing I'm working on is hanging up.
What is likely to be causing that?
