SVG Import in ASP 8.1
idragosani
Post by idragosani »
Using ASP 8.1 and importing SVG made in Inkscape. The SVG was created from text. When importing into ASP, the "holes" in letters like P e and o are separate shapes stacked on top of one underneath, so the hole is a solid filled shape with a stroke outline rather than empty space in the object (they were empty in Inkscape, you could see through them if you moved the object around). Is there a way to use the top shape to cut a "hole" into the underlying shape (like a boolean operation)? Or is something amiss in the SVG import?
Brett W. McCoy -- http://www.brettwmccoy.com
Anime Studio Pro 8.1 : Intel i7 2600 3.4 GHz : 8GB RAM : Ubuntu Studio 11.04 : Cintiq 12wx
This is a common problem in file exchange between vector programs. The technical reason is the ill-fitting direction of the inner curve: to create a hole it must be in the opposite direction of the outer curve.
Different programs have different means to correct this (or none), in AS I think you can erase the shape (so the bare curves remain), then select inner and outer curve together and create a new shape.
You don't have to erase the whole shape. You can just 'break' both shapes, join them up again, and then do your selection thing.
idragosani
I think there was an issue with the font itself (a truetype), I tried re-creating my graphic completely inside ASP (rather than using SVG one) and ran into the exact same issue. I ultimately ended up using a different font altogether that behaved better :-)
chucky
Post by chucky »
I don't know if this will work on your file but I get better results if I Select the paths in inkscape and use the union function , you may find various holes and intersections work properly in AS
