After opening up my .anme file I find that all my images are now place holder images! The only thing showing is one vector layer, and one image!
Why is it doing this! I don't want to redo two days worth of work!
AGH! All my files are missing!
There is nothing to worry about. It seems you have moved the images from the original place they were when you imported them into AS.
Double click on the image layer, select the image tab, click on source image. Now just browse to the area where you moved the image to and select it and all should be fine.
- Víctor Paredes
And to avoid that happening again, I recommend you to check this thread
viewtopic.php?t=19003
