importing photoshop files
Hello,
I am working in AS8.1- I have tried many times to import psd files into AS and no matter how simple the image, it imports as a gray rhomboid shape. I am saving the files in eps format and then using the import function in AS- what am I doing wrong?? Any help is appreciated....
- Víctor Paredes
Probably I'm not understanding, but have you tried to save your file as .psd (and not as eps) and import it to AS?
- Víctor Paredes
I don't use photoshop, but try transforming the vector stuff into raster layers, then save it as psd and import it on AS.kfried27 wrote:Thanks, I will give the png a try
That should work. Exporting to png is fine, but directly import layered psd files save you a lot of work.
Re: importing photoshop files
Hi, did you try this: File/Import/IMAGEkfried27 wrote:Hello,
than pick your *.psd and AS8 asks you: INDIVIDUALLY or COMPOSITE?
1st creats differnt layers (depending on your psd), 2nd the complete pic on one layer.
Hope it helps.
MustJee
