Moderators: Víctor Paredes , Belgarath , slowtiger
d-soldier
Posts: 17 Joined: Sun May 11, 2008 11:43 am
Post
by d-soldier » Fri Dec 23, 2011 12:17 pm
Preview window on left, render output on right... If the layer color is the same as the lower layer color, what are these edges all about? And why hasn't this been fixed in the new version? If anyone found a way around this and I missed it in the forum, please help me out here...
SvenFoster
Posts: 400 Joined: Mon Jun 13, 2011 2:50 am
Post
by SvenFoster » Fri Dec 23, 2011 1:19 pm
as a workaround... if you are only using images you can turn off antialias
I think its something to do with the antialias that has already applied..
(only works on the Export window not render and save.)
viewtopic.php?p=116361#116361
--Sven
What *if* the Hokey cokey *is* what its all about?
jonbo
Posts: 896 Joined: Wed Apr 07, 2010 6:53 pm
Post
by jonbo » Fri Dec 23, 2011 1:33 pm
Posts: 3175 Joined: Tue May 29, 2007 3:31 am
Post
by funksmaname » Wed Sep 12, 2012 12:06 pm
If you're using patch layers, I've found that swapping the order of what is on top and below can fix these issues... worth a try!
