Newbie - Can't seem to add bones in Tutorial 1.4
kingace
Post by kingace »
I have followed the steps completely, but when i try to add the bones, nothing happens at all. I simply click and drag, but the bone does not appear. However, prior to click-and-dragging, the only enabled button is the add bone button, and afterwards, many other buttons are abled to be clicked.
What am i possibly doing wrong with adding bones???
(I did follow the steps)
Lost Marble
Post by Lost Marble »
Click the "Display Quality" popup button at the bottom-right corner of the main Moho window. Check to see if "construction curves" is turned off. If so, turn it back on and you should see the bones.
You could also click the "Medium" button in the Display Quality popup box to set things back to their default settings.
kingace
Post by kingace »
Aha! Thanks alot.
