Finaly got one done
Seyrse
Finaly got one done
Post by Seyrse »
It was quite a learning experience. Hopefully the next one will be both faster and better.
https://www.facebook.com/photo.php?v=330012360347460
Steve E. :D
sbtamu
Post by sbtamu »
Not bad. Thanks for sharing!
Sorry for bad animation
GCharb
Post by GCharb »
Darn, that woman has some set of teeth! :)
Not bad indeed.
H.G. DaGr8One
Post by H.G. DaGr8One »
How did you use picture cut outs?
LET YO' VOICE BE HEARD, BREAK AWAY FROM DA' FLOCK!!!
EMBRACE DA' ILLUSION OF LIFE!!!
GCharb
Post by GCharb »
H.G.
You export the pars of your images in PNG format with transparency.
You load them then use them with bones as if the we're vector layers.
There is a tutorial in the manual.
Seyrse
PNG cut and paste
Post by Seyrse »
Almost all of the heads I used I got from the web. Then via Corel PhotoPaint turned them into .png files. This let me get rid of all the background and set them in a transparent box. After the opening where I used the Anime technique to get the mouths in sync with the audio track
I realized it was going to be faster to just create my own mouths. Many of the pictures I got were close but they all just had these smiling mouths I needed teeth and tongs. For the Anime to look right you need some space in the mouth to spread open and close. Or you get the big BIG teeth like Bachman has.
I just copied the chin area and lower lip, changed the mouth and then put the two back together in a layer that I could move as a unit.
By the time I got to the end the Monty Python method seemed to be working quite well. I did run in to a hang up with layers as how to get the last group of elephants from behind the foreground road layer to in front of it. So I cheated with a dissolve as they came in. I need to play around some more with the layer switch thing and get a real handle on it.
Steve E.
H.G. DaGr8One
GCharb wrote:H.G.
Thanks for the feed back. I do remember reading that in the manual awhile ago.
H.G. DaGr8One
Re: PNG cut and paste
Seyrse wrote:Almost all of the heads I used I got from the web. Then via Corel PhotoPaint turned them into .png files. This let me get rid of all the background and set them in a transparent box. After the opening where I used the Anime technique to get the mouths in sync with the audio track
Steve E.
Thanks for getting back to me on my question, most don't. :( Soooo, Corel Photo Paint (CPP) is the way to go for .png files. Or, basically any program I can use to create a .png file. I have no clue how to use CPP, unfortunately. But, can I just use the head of the image with CPP?
