Howto put a shape over and under 2 layers
patricia3d
Post by patricia3d »
See the Image
There is a shape in Layer:Teeth_Down
and another Layer Upper_Mouth is above this layers.
I want one shape ( see in red points selected ) to come over to Layer Upper_Mouth. Pointed the shape with Yellow Mark.
GCharb
Post by GCharb »
Just put that shape on a new layer and drag that layer on top of the upper mouth layer!
patricia3d
Thanks for guidance. I want half part of the teeth should be covered by down_mouth, but half part of the teeth should be over upper_mouth.
If I create a new layer over upper_mouth, then half part of the teeth how will come under down_mouth?
GCharb
Post by GCharb »
Personally I would use shape ordering.
Depending on how complex that shape is, I'd create a new group, put it inside, and create a mask to show only the top half.
you could also split the top of the tooth with a line, then copy the tooth to its own layer, but only fill the tip (similar idea to slowtiger, but no masking)
or, if you changed your design slightly so that the bottom lip doesn't need to go under the top lip you could put that (or split and put the front part of it) in a layer above the top lip so that you can put the teeth in between...
SvenFoster
Post by SvenFoster »
GCharb wrote:Personally I would use shape ordering.
how?
--Sven
What *if* the Hokey cokey *is* what its all about?
GCharb
Post by GCharb »
I would put the whole mouth on one layer and make the whole tooth at least two fill shapes and use shape ordering to make the upper part of the tooth on top of the upper mouth.
SvenFoster
ahhhh I thought you had a way to animate shapes.. i get you now. thanks
--Sven
GCharb
Post by GCharb »
Wes (synthsin) has a script for that on the other forum.
patricia3d
slowtiger wrote:Depending on how complex that shape is, I'd create a new group, put it inside, and create a mask to show only the top half.
Thanks slowtiger.
Actually I have to use for swf, no mask there?
Any other idea?
Do as funks says: copy the tooth, tweak the points, swtitsch some line segments invisible.
