I've put in two wav. files overlapping in my animation, and the gurgling water noise is too loud for the voice noise. I went to Layers, Gurgle, Audio, and it didn't look like there was much volume control? I set the Audio Level on zero and it's still way loud. I guess I'll just make the other one louder, but just wondered if there was another way to adjust. Thanks!
Audio Files Volume
- funksmaname
double clicking on the audio layer and going to the audio tab, there is an audio level setting. Changing this will change the volume, and doing so along the timeline will animated the volume... although you describe changing this to 0 here, the only explenation I can think of is that you're not changing the audio layer that you think you are. Try it with a single layer so you can't get confused and see if you get expected results.
