units of the Vector2 X&Y
bogush_r
Post by bogush_r »
Hello, All!
I have some questions:
Which units used in the x,y cooordinates of the Vector2 class? Which ratio between screen dimensions and that units? If screen center is the "zero point", how can be found cooordinates of the screen edges?
myles
Re: units of the Vector2 X&Y
Post by myles »
Hello bogush_r,
bogush_r wrote:Which units used in the x,y cooordinates of the Vector2 class?
Moho units! Any resemblance to real world units is purely illusory.
bogush_r wrote:Which ratio between screen dimensions and that units?
There cannot be a fixed ratio between screen dimensions and Moho units, because:
  • you can zoom the workspace (mouse scroll wheel, shift-right-drag)
  • you can resize the main Moho window
  • you can change your screen resolution
  • you can view the same file on different computers and/or monitors
All these change the screen size of an object, and the screen size of the camera view, without changing the object size in Moho units.
bogush_r wrote:If screen center is the "zero point", how can be found cooordinates of the screen edges?
Not an answer but a comment:
This won't necessarily relate to the size and position of objects (or layers), because:
  • you can move the camera backwards and forwards
  • you can zoom the camera
  • you can pan/tilt and track the camera
  • you can scale, translate, and rotate a layer
  • you can change the depth of a layer
All these change the relationship of an object to the edges of the camera (screen) view, without changing the object (Moho units) size or position.
Note: you can also change the camera dimensions in the project settings, which will change where an object is placed in regard to the edge of the camera view (if, for example, you change from NTSC to NTSC 16:9 with an existing object). Changing a layer origin will also change an object's (Moho units) position without changing its position on the screen.
Note: the screen edges (in Moho units) might be different for different layers if the layers are not all at the same depth and the layer origins are not all in the same place.
Having said all that, there are some scripting functions that are related to screen units. Have a look at the scripting documentation for:
  • the Point2Vec() function of the MOHO.MohoView class
  • the LM.Point class
  • the LM.Rect class
Perhaps if you could say what you are trying to achieve someone could come up with a more useful answer?
Regards, Myles.
-- Groucho Marx
7feet
Post by 7feet »
I don't remember it exactly, as I've been busy with some other stuff. However, the basic Vector2 measurement, in an unscaled or otherwise messed with layer, relates to the vertical (Y) dimesion of the project size. If you place a point at 0, 0, you are dead center. 0,1 puts you right on the top edge of the project. This holds with whatever ridiculous project dimensions you might feel like whipping up, and will stay consistent, based on the Y size of the project no matter how much you change it.
To find where the X sides of the project are, you need to either pull out the project size e.g.
local w = moho.document:Width()
local h = moho.document:Height()
(I'm pretty sure that's the syntax) or you can use the AspectRatio() function to get a ratio directly, I'm not sure off the top of my head but I believe the Y is the 1 in a, say 1:1.66 ratio, and the function would return the 1.66 part for the X.
The numbers seem to hold for the X/Y parts of the Vector3 class as well.
If you need to find when a point is at the edge of the screen, I guess you could put together a matrix with all the various layer and camera transforms, compare it to a rest state matrix, and figure out where you are. Or something like that. That can add up to a bunch of 3D muck that I still have some trouble wrapping my head around, but it's far from impossible. I just can't picture it right now, too tired.
Also, Myles, in a quick 2 second test, changing the Layer Origin doesn't do anything directly to the position, either on screen or by the numbers. I used to have some wierd things happen on-screen when I had changed origins, but that seems to have been cured.
myles
Post by myles »
Ah, much more useful information! Thanks Brian!
I must have been doing something particularly silly yesterday, like reading the origin position instead of the point position, because I had another look at moving the layer origin today and you're absolutely right.
Regards, Myles.
-- Groucho Marx
Lost Marble
Post by Lost Marble »
7feet wrote:I don't remember it exactly, as I've been busy with some other stuff. However, the basic Vector2 measurement, in an unscaled or otherwise messed with layer, relates to the vertical (Y) dimesion of the project size. If you place a point at 0, 0, you are dead center. 0,1 puts you right on the top edge of the project. This holds with whatever ridiculous project dimensions you might feel like whipping up, and will stay consistent, based on the Y size of the project no matter how much you change it.
Similarly, the point 1,0 puts you at the center of the right-side edge of the project if the project is square-shaped. If the project is non-square (as most are), then one unit in X is still the same as one unit in Y, it's just that where you end up depends on the aspect ratio of the project.
Also, I should mention that all this only applies to the default camera and layer positioning. If you move a layer around in 3D, or point the camera in a different position, that will change where an X,Y point maps to in screen space.
jasonrfox
Moho data format
Post by jasonrfox »
I'm working on a program that needs to know the location of the corners of a layer in image space coordinates after Moho applies all of its transformations.
After a lot of experimenting, I assume that Moho treats everything in 3D and uses 4x4 tranformation matrices to apply layers to their final shape and position. What is the composition order of the tranformation matrices? Moho supports rotation about axes (Rl), translation (T), scale (S), and shear (Sh) applied to a layer, and translation (Tc) and rotation (Rc) to the camera:
(I assume the rotation composition order is R = RxRyRz)
Mcamera = Rc Tc
Mlayer = Sh S Rl Tl
therefore
Mfinal = Mcamera Mlayer = Rc Tc Sh S Rl Tl
My thought is that I can construct the component matrices: Rc, Tc, Sh, S, Rl, and Tl using the keyframe parameters. Then if I know the order they are applied I can multiply them into a composite transformation matrix. Finally given any point in the layer's original space I can compute its location in final image space (or vice versa after inverting the matrix). That's a lot of work so I'm hoping someone has a simple answer before I take a plunge.
Maybe there's a LUA command for this already but I couldn't find it.
Thanks for the insight!
7feet
Post by 7feet »
It's
GetFullTransform(<frame number - moho.frame>, <matrix to put the transform>, <the Moho document - e.g. moho.document>)
look in the MOHO>Classes>MohoLayer section of the Scripting Reference. This returns a complete (and you're right, it's 4x4) transformation matrix for the layer, including the effects of all it's parent layers. You also have GetLayerTransform() for just that layer, or GetParentTransform for just the parent layers transform. The latter I am not sure if it is only the specific transformation of the parent layer, or the parent layers full transform, I haven't used that one.
Not sure about the order for the camera. You might dig around in the Track Camera script, maybe give you a clue in the interim.
jasonrfox
Thanks for the pointer!
Post by jasonrfox »
Thanks -
That helps a lot. It takes a while to learn an entire API and sometimes its tricky to find just the right function - you saved me a bundle of time.
jasonrfox
How to get the final camera matrix transform?
Post by jasonrfox »
GetFullTransform works very nicely. However it does not include the camera. GetOutsideViewMatrix only returns the orbit transform. If the camera is in the default render state as with a ResetView then it only returns an identity matrix. Is there an easy way to get the camera matrix as it will be rendered at each frame? I've done tons of searching and it appears not.
I've been painstakingly trying to reconstruct the camera transform from the animation parameters. After many days of trial and error I still haven't got it right. The hardest part is the zoom which I'm trying to map to Perspective. I know the matrix order is critical and the second issue is how to get the perspective projection correct? (A related question is how to print the matrix to the LUA console?)
The answer I'm hoping for is what function will return the camera transformation given a frame number OR how do I construct that matrix given the camera inputs: fCameraTrack, fCameraRoll, fCameraPanTilt, and fCameraZoom?
Here's my current attempt.
	local startFrame = 1
	local endFrame = 1 -- moho.document:EndFrame()
	local layerMatrix = LM.Matrix:new_local()
	local cameraMatrix = LM.Matrix:new_local()
	local point = LM.Vector2:new_local()
	local currentPanTilt = LM.Vector2:new_local()
	local near = 0.1 -- What near and far planes does Moho use?
	local far = 100.0
	aspect = 600 / 400 -- Assume a 600x400 image just for easy testing
	for currentFrame = startFrame, endFrame do
		print("Getting tranformation for frame " .. currentFrame)
		-- Get the interpolated values for the current frame
		currentPosition = moho.document.fCameraTrack:GetValue(currentFrame)
		currentRoll = moho.document.fCameraRoll:GetValue(currentFrame)
		currentPanTilt:Set(moho.document.fCameraPanTilt:GetValue(currentFrame))
		-- Moho appears to scale a zoom of 1.0 to a FOV of 60 deg
		currentZoom = math.rad(60 / moho.document.fCameraZoom:GetValue(currentFrame))
		-- Construct the camera transformation matrix
		cameraMatrix:Identity()
		cameraMatrix:Perspective(currentZoom, near, far, aspect)
		cameraMatrix:Translate(currentPosition.x, currentPosition.y, currentPosition.z)
		cameraMatrix:Rotate(LM.X_AXIS, currentPanTilt.x)
		cameraMatrix:Rotate(LM.Y_AXIS, currentPanTilt.y)
		--cameraMatrix:Rotate(LM.Z_AXIS, currentRoll)
		cameraMatrix:Invert();
		-- Get the transformation matrix for the layer
		moho.layer:GetFullTransform(currentFrame, layerMatrix, moho.document)
		-- Compose the camera and layer matrices
		cameraMatrix:Multiply(layerMatrix)
		-- Try transforming various test points (I change this as needed)
		point:Set(0, 0)
		cameraMatrix:Transform(point)
		print(point.x .. " " .. point.y)
	end
LM did a fantastic job making so much available through the scripting interface. Maybe what I need is there too!
Thanks!
jasonrfox
Post by jasonrfox »
Hmmm...
I worked out the matrix composition order. Now I can reconstruct the camera transform. Then I started adding in the layer transformation again and realized that GetFullTransform may actually be the final matrix. I think I was expecting something else. It's a little unintuitive at first that the coordinates are wrt a proportion of the document height.
LM, can you confirm that GetFullTransform returns the result of the entire matrix stack, including layer transforms, bones, and camera?
As an aside, the camera roll seems to be applied differently than the other parameters. To construct the camera matrix all of the parameters need to be negated except the roll.
thanks again
Lost Marble
Yes, GetFullTransform does include the camera - it is the full and complete transformation matrix for that layer.
A little twist to the above: if you include the document object as the last argument to GetFullTransform, then the camera effect is included since the camera is really part of the document, not the layer. If you leave out the document object (passing in nil instead), then the camera is excluded from the matrix you get back.
