To AS Beta team push the software to it limit to find bugs next time you pros may say i am wrong but i am just being honest that's me HOTHEAD
AS 8.1 1 found 2 insect (b_g)
- funksmaname
Absolutely, You need to report anything that does not work as it should and that can be reproduced.Rudiger wrote:True, but you can't know for sure until you investigate it and you can't investigate it until it's been reported!GCharb wrote:Most of the time bugs really are just a mistake peoples make.
- funksmaname
I'm not on any team - and I never saw you flamed for a previous bug report - you're just making a scene with this 'I found a bug but I won't tell you coz you'll flame me'... just report the bug in the bug section!
There's no possible negative outcome - if nothing else there might be a workaround someone can come up with to get around the bug till it's fixed.
SvenFoster
SvenFoster
Now look hothead. I assure you it's nothing personal. If you think you have discovered a bug then why not...
* put a post together describing how to recreate it.
* if possible post a link to a simple file that people can use
* state which version you are on
* state which operating system
Then you will find the generous souls on this forum will
* verify it
* suggest work around to help you.
Then *submit a bug report*
I guess you are feeling a bit upset because another thread didn't treat you right. I understand. I do.
I myself only moments ago got upset at your thread
now lets salvage it.
Go on. Tell us the secret bug. Pleeeeease.
* verify it
--Sven
What *if* the Hokey cokey *is* what its all about?
