Character design/ point question
Matsuemon
Post by Matsuemon »
Hey guys,
I've got a couple questions about character design and points, and am still getting used to AS7 Pro, but haven't hardly done any design yet. If I want to animate a head turn, for instance, and the head is turning from straight ahead to the left (the characters right), some of the points on the right side of the characters face (particularly the ear) will have to be hidden, is that right? Also, how important is it that the amount of points on each side of the head are the same? I mean, can you have an extra line of points on the left side of the face, for instance, that isn't on the right?
I know some people do almost everything with point animation and some do it with morph blends or switch layers, so just trying to figure out some of the obstacles I might face before spending a lot of time designing a character.
Anyway, thanks for any advice and I'll start messing with this more today.
GCharb
Post by GCharb »
As far as hiding parts of the body goes, usually You build parts on different layers, so that You can use layer order animation to hide them.
As far as the amount of point needed, the way I do it is this.
I try not to use point curvature, instead I add enough points for good curvature, which usually gives me enough point to work with.
I also find that shapes animate better with default curvature on all points instead of varying amount, but that's the way I work, others may have a different view on such workflow.
Matsuemon
Post by Matsuemon »
Hello again GC!
Ooohhh yah I forgot about the layer animation thing. I guess I'll just start designing and I can always tweak later. =) Thanks for your help
GCharb
Post by GCharb »
Yeah, just lay down shapes, tweak, re order, mess things up, clean up, and have fun! :)
Matsuemon
Post by Matsuemon »
Actually, I have another question for you guys who are designing characters in AS. I'm curious to know how much detail you are putting in your models and if any of you are designing characters with layered clothing. For example, I recently designed a cowboy character I was planning on animating FBF, but now I'm wondering if it's doable in AS, but he'll have some layered clothing on his upper body, like a shirt, vest, then a jacket over that, so you'll see parts of all those. I wonder if that would be too much of a pain in AS?
GCharb
Post by GCharb »
Here is a character from my tutorial video set.
I only add the parts that will be showing, as underlying parts gets rendered and add to render time.
So in this case, I only created the colar of the shirt, not the shirt itself.
Matsuemon
Post by Matsuemon »
Hey Gilles, yah that makes sense about the rendering thing. Thanks for the example, and I can't wait for the videos to be finished!
GCharb
Post by GCharb »
Almost done with the voice overs, last thing I will need to make is the final scene.
straffax
Post by straffax »
GCharb wrote:As far as hiding parts of the body goes, usually You build parts on different layers, so that You can use layer order animation to hide them.
This makes me curious, is it possible to animate the layer order? So that the visibility order of layers changes during the animation?
Yes.
straffax
Post by straffax »
slowtiger wrote:Yes.
Now this makes me even more curious - how?
Go to the group/bone layer which contains your layers, open the proprieties, go to Depth sort and check Enable animate layer order.
Now, every time you change the order of the layers it contains, you will see a keyframe on the group/bone layer.
straffax
Post by straffax »
Aha, found it! So that's how...
Maestral
Post by Maestral »
* Boy, oh boy... were you fast or what ,)
Matsuemon
Post by Matsuemon »
Hey guys, I have another character design/points question so I'll just add it to the thread I already started :wink: . I'm wanting to create a character who is wearing a hat, but you'll be able to see part of his hair under the hat. My question is, will the hat be on it's own layer and I will still create a hair layer even though only part of the hair will be visible but not the whole head?
I'm thinking I'll use masking for this type of thing? Thanks for any help.
