Flash render, Moho closes!
I've made quite a complex scene, the file size is about 1.4MB (i've never made anything this size before!). I can render to video and image formats fine, but i can't export to flash.
I get everything set up to export to flash, click "OK" and MoHo shuts down. I've rebooted my computer, done the process again, MoHo closes. Change the flash export settings, still closes.
MoHo File
I've attached the file, please don't go nicking any background and character work, although you can use it to play around with (personal use) if you want to.
I'm using WinXP (1.61Ghz machine), lots of RAM (1GB) and the latest version of MoHo, which is 5.2.1 i believe.
Thanks
MoHo File
Thanks
--Scott
cribble.net
cribble.net
Just another data point: I see the exact same behavior when running on linux (Fedora Core 3). But, it does give this error message to the console:
Maybe this can help LM track it down.
Curve parameters too large
Downloaded your file to take a look (got Win XP, 1gig memory), and it wouldn't load (something about an error round frame 15688(!)). So maybe your source file is too big?
Another funny thing -- looked like the file was around 1.4Mb when it was downloading, as you said, but sitting in a directory it's around 250k. Which is odd. Sorry I can't help.
J
J
I've tested the download and it works fine. I'm not sure about the error, i don't seem to be getting it.jahnocli wrote:Downloaded your file to take a look (got Win XP, 1gig memory), and it wouldn't load (something about an error round frame 15688(!)). So maybe your source file is too big?
J
--Scott
cribble.net
cribble.net
Right, after fiddling around with the file for a while i found out what the bad smell was... the amount of points. I discovered, by reducing the amount of points, thus making the file size smaller, in certain "over-crowded" layers, that MoHo becomes stable once again to export to flash.
I think this is a bug that needs further seeing to, if possible. I've left the original file as a "just in-case" measure in case you want to see the "roots" of the problem. And anyone out there, with big MoHo files (about 1.4MB and beyond) please check the flash export and report back.
Cheers for the help.
Watching way too many detective programs.
--Scott
cribble.net
cribble.net
Right the error has come back again. It seems to be a layer problem, not a document problem.
--Scott
cribble.net
cribble.net
- Lost Marble
Sure.
http://www.freepgs.com/cribble/moho/scene2.moho
If the link doesn't work, copy up until "moho" and just download it from the open directory, it should work though... hopefully (works fine on the PC).
--Scott
cribble.net
cribble.net
- Lost Marble
OK, I tracked the problem down. The problem is with the lowest layer in the project, BG1. This consists of a very wide rectangle. Because your project dimensions are so large, 1024x576, the rectangle is especially wide in pixels. Flash stores coordinates using fixed-point numbers, not floating-point. If you don't know what that means, don't worry about it - it just means that you can hit some limits in Flash sooner than you might otherwise.
There are two things you can do here:
1. Set your project dimensions lower. For example, 320x180. It's still a 16:9 ratio, and since Flash is vector-based, you can make the player window bigger on playback if you want.
2. Shrink the rectangle in the BG1 layer. It doesn't seem to need to be so wide. I used this approach in the file below:
http://www.lostmarble.com/misc/scene2_fixed.moho
And here it is after exporting to Flash:
http://www.lostmarble.com/misc/scene2_fixed.swf
I'll see what can be done about Moho closing in this situation. Moho uses a third party Flash-exporting library that unfortunately exits when an error is encountered instead of reporting the error to Moho and letting Moho deal with it.
ahhh-haa, thanks alot. It was doing the same thing when i imported the background into another scene. So the flash export can't handle huge shapes beyond a certain point... looks like i'll have to be careful.
Thanks again.
Thanks again.
--Scott
cribble.net
cribble.net
- Lost Marble
- Lost Marble
A new discover here lads! MoHo doesn't like to export, to flash, huge picture sizes.. i mean anything beyond 3500x1600 (ish). It crashed again, even upon resizing it within the moho environment. Solution: Resize image outside of moho.
--Scott
cribble.net
cribble.net
