How do I make my character stop/start walking?
Bradshaw
Post by Bradshaw »
Im working on somthing right now, but I want to have him stop at one time then start walking again later.. When I have him stopped he keeps doing the walking motion, but isnt going anywhere.. Please dont tell me to "go read the manual.." just tell me if you know what im doing wrong.
how are you making him walk? is it on a bone layer with a walk action? is his movement controlled by layer translation? if so, and when the layer stops the walking action continues, you just need to interrupt the looping action by putting a key frame on the bone layer - freeze him in a standing position. He should walk up to that point. To start again, go to the frame you want to start and lay down the walking action again and it should loop.
Bradshaw
Post by Bradshaw »
"interrupt the looping action by putting a key frame on the bone layer - freeze him in a standing position"
How do I do this?
right click on the timeline bone lane and select 'insert keyframe'
or move the bones manually and a keyframe will be created
Bradshaw
Post by Bradshaw »
Ok, thanks. Can you tell me what this red line is?
sbtamu
Post by sbtamu »
That is the cycle back to a frame line.
Sorry for bad animation
the arrow is where the cycle starts - then any key after that will interrupt the cyle (so in this case, you'll get 3 frames from the start of the cycle at frame 7 (i think) and then the cycle will stop. Move the dot after the arrow to lengthen the cycling duration...
...and read the manual.
Bradshaw
Post by Bradshaw »
How do I change direction while im walking?
And I am reading the manual, but I don't really see anything on movement..
I would flip the layer, and then do a few manual animation frames either side to sell the turn... learn the basics first though. have you done every tutuorial?
Bradshaw
Post by Bradshaw »
I did every single one except for a few simple ones, because they are common sence but the stuff I need help with isn't included in there :/
what about tutorial 5.5 on pg 138 of the manual: Cycling?
neeters_guy
Post by neeters_guy »
Bradshaw wrote:How do I change direction while im walking?
You mean have the character face in a different direction? You need to draw each view and use a switch layer to change the view, like this:
Character Wizard Walk Test (Anime Studio Pro 8 )
To change direction simply flip the top layer of your character.
wizaerd
Post by wizaerd »
I truly appreciate the members of this forum, most of them are just the nicest people in any forum I visit, but man, sometimes you're all just too nice. If someone can't even be bothered to learn the basics, using the manual or any of the many, many tutorials available, they certainly shouldn't expect to have their hand held. Walking, not walking, flipping... All quite basic stuff, covered in depth in the manual and again, in many of the multitude of tutorials available.
Bradshaw
Post by Bradshaw »
funksmaname wrote:what about tutorial 5.5 on pg 138 of the manual: Cycling?
pg 138 on my manual is the draw shape tutorial.. Are there different types of manuals?
