animation speed
alevinson
animation speed
Post by alevinson »
The default speed for animations is 24 frames a second. I want to slow it down. There are 2 ways I can do this, 1. slow it to 6 frames a second or 2. spread out the animation over 4 frames keeping it at 24 frames a second. Since I want to export it as an NTSC file which is the best way to do this?
alevinson
GCharb
Post by GCharb »
Not sure what You are asking here.
You want your animation to go in slow motion?
If You are plannnig to output to NTSC You need 29.97fps, but that's a pain to animate, just stick to 30.
You need to distinguish between the fps rate of a film/video, which ist constant, and the number of drawings per second, which can vary.
Maestral
Post by Maestral »
It really depends on what you want to do.
If what you need is a slow motion of action in your existing animation (or any other time shift), that would be better to do in some of the editing app`s.
alevinson
exporting slow animations as an NTSC file
Post by alevinson »
In reply to my previous question. I am sorry for the confusion. If I do my animation using 6 frames per second instead of the Anime Studio Pro default of 24 frames per second, will I be able to export my animation as an NTSC file?
alevinson
GCharb
Post by GCharb »
Absolutely, the conversion is easy and any video editing software worth its salt will do it.
