Adjusting stroke thickness over handreds of layers
GM
Post by GM »
is there any way to change stroke width over several layers together at one time??
I am having big trouble ,,,, please save me. :cry:
you can create an style, apply it to all the shapes you want and then change the width from the style window.
This doesn't work for variable line widths.
GM
thanks,,,,,but
Post by GM »
thank you so much for the reply.
but problem is,I already did set up many scenes.and it is done animating.
so I was wondering if there are any way to change only thickness just like DS_ColorTool?
you should only have to do it in frame 0 anyway of each scene so the fact its already animated isn't really relevant. In future, use styles from the start and you'll avoid any problems but you probably have to go manually and edit them.
Both Rudiger's and Synthsin's shape select tool allow you to apply stroke information to many shapes at once (only on the same layer but still helpful) although Rudigers tool costs money (but is great) and Synthsins is only available in the animatorsforum.com script section which you need to have 50+ posts to gain entry too (it's also a fantastic tool)
Perhaps there's a way to open the AS files in a text editor and change settings in there with find/replace of a text editor - but I've never tried it so you're on your own.
oferhod
Post by oferhod »
I did some fixing like this long ago:
First - Backup your file
Then - Open the file as a text file, try to locate the thinckness (it's VERY hard).
Use the find and replace function.
Lats thing - pray really hard
Open the file again, this time as a ASP file (while still praying..).
Good luck
I had to redo the process few times before it worked as I wanted :)
