animatable line width!!!
sweet!!!! this is a great addition.
thanks Lost Marble!
looking forward to discovering the other new features...
thanks Lost Marble!
...Really you can't imaginate any???
I've been waiting for this since I knew Moho and I'm very
HAPPY
for this adition too! And want to take advantage of this post to say again: THANK YOU (very much) LM!!! ...This will be very usefull (to me) for maintain the aparence of my characters in morphins and head/ body turnings (i.e) and
I've been experimenting with noisy keyframes for interestings noisy line efects too! I think that this feature bring us TOTAL control of ours shapes along the time and that is GREAT! *CIAO*
PS:
PS:
Let´s see it in action!
I can´t visualize it - I want to see an animation of it.
(I tried it and it did not look so good
- so I must not know how to use this feature properly.)
So I want someone who can do it, show me an animation so I can go - Ah-HA!
Now I get it.
Ramón, do you have one to show us?
Just like Moho 5.2 has embedded scripts - I can´t do that (or really understand it) and am waiting for those that can do it to post some scripts so then I can go - Ah-Ha! Then my imagination will kick into gear and come up with some good ideas to use them.
Here is my test using Moho´s new animated line widths function.
Animated Line Widths.mov
When would some one use thin then fat then thin line widths in an animation?
I know there has to be lots and lots of ideas, but I am stumped.
Please post your animations showing your creative uses of the animated line width in action.
Toontoonz wrote: Ramón, do you have one to show us?
Mmm...About that you say of animatable Line Width can be that exist a little bug with Reset Line Width points when you create your first keyframes (between the 0 keyframe up to the next), I've experimented some weird results with that and thought to put it in Bug Reports but I was not completely sure... Seems that if in frame 0 you modify Line width in ALL points (for do it "not reset points") the problem disapears... I'll go on investigating and when I be sure, I'll put it in Bug Reports or, LM, if you read this and tell us something about, I (of course) won't put it... *CIAO*
I don´t know anything about the RESET bug you are discussing, but I found a use for the animating line width:
A new way to make a mouth talk (and moving expressive eyebrows)!!!:
Use for Animated Line Width
I look forward to seeing some better ideas than this one!
This was just some random play. Not sure that they show anything useful but I did use the animated line width for all three and they aren't even pretty. One thing I do think we need is the ability to Reset Line Width -doesn't seem to work like Reset All Animations for example?
http://stormvisions.com/moho/lines1.mov
http://stormvisions.com/moho/lines2.mov
http://stormvisions.com/moho/lines3.mov
Re: animatable line width!!!
BA - I think you made the original request to LM to animate line width in Moho - what are you using it for? Please post an animation or two of it in action.BA wrote:sweet!!!! this is a great addition.
i hope i'll be able to soon....
unfortunately i have to spend all day working in flash...
but late into the night you can bet i'll be animating line width.
I think the real usefulness of it is that now you can really morph any shape into any other shape, without being quite so limited by your original shape... ideal for head rotations, perspective shifts, etc...
actually, what would make this really really useful, is if you could reduce line width to 0 if necessary. The minimum line width still shows a tiny line.
It would be very helpful to transitions, morphs, head turns etc, if you could animate segments of lines appearing and disappearing, without having to build them as separate objects...
feature request?
feature request?
